Starting problem!!?!? Please help!
Old Jun 22, 2019 | 08:03 PM
Robert_West01's Avatar
Default Starting problem!!?!? Please help!
I have a 2000 civic sedan. I swapped it to b18b1 and to a manual. It started and ran for a few days then one morning didn't want to start. It only starts sometimes now. It's very random. When it don't start it don't make any noise what so ever. I turn the key all the way and it don't click or anything at all. My cluster shows that I am in park so I am 90% positive I wired the auto to manual right. I tested the battery and starter and they are both good. Checked fuses and they are good. Could it be the ignition switch? Or somewhere the wiring is frayed or messed up?? Please help!!! It only randomly starts, and then 70% of the time does not start!
Old Jun 23, 2019 | 04:20 AM
muellersfan's Avatar
Default Re: Starting problem!!?!? Please help!
When the engine does not start, turn key to ON(II) position. Does the fuel pump prime? Does the CEL turn on for 2 seconds and then turn off?
Old Jun 23, 2019 | 06:43 AM
Yes it turns on and then turns off, dash lights come on and so will headlights, when I fully start the dash lights come off as normal
Old Jun 23, 2019 | 09:34 AM
Originally Posted by Robert_West01
Yes it turns on
Are you referring here^ to the fuel pump priming/running for 2 seconds?
If so, connect a wire to the (+) battery post.
Put transmission in neutral and set parking brake.
Unplug starter solenoid wire.
Touch hot wire to starter solenoid pin.
Does the starter crank the engine?
Old Jun 23, 2019 | 09:39 AM
Yeah i can hear the fuel pump prime for 2 seconds
Old Jun 23, 2019 | 09:42 AM
Do this:
Connect a wire to the (+) battery post.
Old Jun 23, 2019 | 09:55 AM
Do this:
I got the starter tested at AutoZone and it passed easy, but I will try that when I get home
Old Jun 23, 2019 | 10:12 AM
It's informative to test the starter function in place, but you can also test whether battery voltage reaches the disconnected starter solenoid wire when the key is held in ON(III), of course when the engine won't crank.
Old Jun 23, 2019 | 10:51 AM
Okay I'll check when I'm off and reply thank you
Old Jun 24, 2019 | 12:18 PM
Okay so when my car does not start, I took a wire to the positive terminal and took the little wire to the soliniod of the starter and it sparked a bit but does not start! Omg so sad I hate this lol
Old Jun 24, 2019 | 12:23 PM
If you are convinced that the starter is good, the next step is to carefully clean and tighten the two important ground wire connections in the starter circuit:
Both G3 transmission to chassis ground connections
Both G1 battery (-) post to chassis ground connections
Old Jun 24, 2019 | 12:27 PM
Okay so they are both tight but I did paint my engine bay before the swap, could that be an issue? How would I insure I have a solid ground? Just sand the area down? Could it be the wiring to the ignition? Or the ignition itself. It's really confusing because it worked before the swap and sometimes works still. I am highly doubting it is the ignition switch itself or the starter and battery. It has to be wiring or ground. I just don't know where to track it down
Old Jun 24, 2019 | 12:42 PM
Your test result RULES OUT the ignition switch.
Remove ground bolts and clean off corrosion and paint with wire brush or wheel.
Rent thread restorer kit from AutoZone to clean paint and corrosion from ground bolt hole threads.
https://www.autozone.com/loan-a-tool...kit/391372_0_0
Fire up engine and drive.
Old Jun 24, 2019 | 12:45 PM
Okay so I sanded it and it started but it could have just started like a random time so I'm going to wait an hour or 2 to get back to you and see. Thank you so much by the way!
Old Jun 24, 2019 | 12:47 PM
The rental tool is free at AutoZone. Get it.
Clean all G1 and G3 ground bolts and holes thoroughly to make fix permanent. You do NOT want to worry about the car breaking down again.
Old Jun 24, 2019 | 12:56 PM
Yeah the guy who helped me swap said it's fine to just put the ground in, I painted the bay before putting the motor in so I was concerned if that is an issue but he said it shouldn't be, maybeit just was lol
Old Jun 24, 2019 | 01:06 PM
Engine bay painting is well known to cause problems with ground connections.
Old Jun 24, 2019 | 01:10 PM
Just started car again and all seems good, I'll message back if anything happens later or ever again. Thank you all for helping me I really appreciate it!!
