car is not level when jacked off the ground
Old Jun 19, 2019 | 11:52 PM
billybod's Avatar
Default car is not level when jacked off the ground
on the ground, the car seems to be leveled, but jacked up with hydrolic jack, one side seemed to be higher than the other side. I used the designated jack spot at the front on my 1993 hatchback. the driver side is higher than the passenger side. any thoughts? it could be that the jack location does not distribute the weight evenly on my hatch, but why would the manufacture does that..
Old Jun 20, 2019 | 02:20 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: car is not level when jacked off the ground
Let me guess....you're jacking up the car at the radiator support....which ISN'T centered.
Old Jun 20, 2019 | 09:56 AM
billybod's Avatar
i don't think i was using the radiator support. my front bumper was off, it was easy to see the jack location
Old Jun 20, 2019 | 12:32 PM
tony_2018's Avatar
Fish Twig
there is a spot under the radiator support to use a hydraulic jack BUT I cant say whether the strength of the support is the same across non OEM supports.
Old Jun 20, 2019 | 12:34 PM
billybod's Avatar
i just double checked the spot again 30 mins ago. that was the spot that i used, at the front, near the radiator.
Old Jun 20, 2019 | 01:09 PM
tony_2018's Avatar
Fish Twig
Yeah its not centered but still a jack point.
Old Jun 20, 2019 | 06:57 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
To add to the discussion, when you jack the car up from one side or the other it does torsion the body to some degree. Once on jack stands, you will sometimes notice one stand doesn't touch. I believe this is from the body roll torsion that happens when you lift one half the car up from one corner. This will settle out over time once on the road again.
Old Jun 21, 2019 | 01:50 AM
NVturbo's Avatar
O.G. triple O.G.
Just look at that jack point. It's located more towards the driver side than passenger.
/thread
Old Jun 21, 2019 | 01:52 AM
billybod's Avatar
I think you are right, i did noticed that too...a bit toward the driver side
Old Jun 21, 2019 | 08:29 AM
NVturbo's Avatar
O.G. triple O.G.
the hood latch mechanism is the center of the car. If you're looking at it, the welded lifting point (under the radiator support) is to right about a few inches.
