Honda CR-V & Element 2WD & 4WD Element & CR-V
2013 CR-V High Mount Brake Light Bulb Replacement
Old Jun 18, 2019 | 08:54 AM
Debbie Bell's Avatar
Default 2013 CR-V High Mount Brake Light Bulb Replacement
Hello all! I am needing to replace my high mount third brake light on my 2013 Honda CR-V 4WD - I looked up the replacement LED red bulb and have in my possession (assuming it is the correct one). Looked on YouTube for instructions. Not there. Went to Owner's Manual and it states to take to a Honda Certified Technician. This independent gal is not going to go that route, unless I absolutely HAVE TO. I have removed the panel inside the hatch door, but clearly that is not the correct place to go. Is my next move to removed the lens? Thanks in advance for any help!!!
Old Jun 18, 2019 | 09:45 AM
canister's Avatar
5 Year Member
Default Re: 2013 CR-V High Mount Brake Light Bulb Replacement
Yes, it's in the lense. IIRC it's held by 3x 10mm bolts under the rear hatch.
And this is the video you are looking for:
Old Jun 18, 2019 | 09:48 AM
Thank you so much!
I did see that video and dismissed it thinking it was the wrong one
I will give this one a try soon!
