Pleaseeeeee Help! 1997 Honda Accord Ex vtec
Old Jun 17, 2019 | 08:05 PM
Jokez's Avatar
Default Pleaseeeeee Help! 1997 Honda Accord Ex vtec
I have done everything! Cap and rotor, wires and plugs, valve cover gasket, fuel filter even changed the injector for the 3rd cylinder since that is the code that continues to drive me absolutely nuts. I am getting a P0303 and P1399 codes that will not stop haunting me. If anyone has any information i or ideas on what’s going on please help.
Old Jun 22, 2019 | 01:27 AM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Pleaseeeeee Help! 1997 Honda Accord Ex vtec
Did you verify valve clearance?
Did you verify the EGR manifold and runner ports were clear?
Both of these will contribute to misfire codes.
Old Jun 21, 2021 | 06:20 PM
steveacura17's Avatar
I would look into the short term fuel trim, the ECU is correcting a lean issue with 18.75% more fuel... vacuum leak maybe. A normal short & long term trim should be between -3% to +5%.
Old Jun 21, 2021 | 08:53 PM
Jack Gorlick's Avatar
I don’t know allot but no one has said anything about a compression test yet ... if you have low compression it will make you misfire as well . They will loan you one at auto zone
also I thought I had a dead cylinder a while ago if you pull the plug and there’s any rpm drop the cylinder is not dead
Old Jun 21, 2021 | 08:57 PM
Oh yea and you can check those fuel injectors as well get yourself a flat tip screwdriver put it on the injector and ear to the other side, if you hear a ticking there functioning
but I think .. I’m not shure .. they might be clogged even with the tick try some fuel treatment as well
oh my bad I thought it was for a single cylinder
still check for oil in spark plug wells though
Donald Deese
Honda Civic (2001 - 2005)
May 5, 2021 06:22 PM
jerhigdem
May 5, 2016 07:56 PM
cg1shawn
Jun 7, 2014 05:43 AM
leflore
Dec 23, 2012 07:44 PM
