Accord swap
Old Jun 10, 2019 | 01:08 PM
Stancedlowerd's Avatar
Default Accord swap
Hey guys need some help here I have a F23a vtech 2.3 L and trying to swap it in a 1995 Honda Accord ex coupe will the harness match the harness inside the dash ?
Old Jun 10, 2019 | 08:53 PM
bavarianbl3ss3d's Avatar
Default Re: Accord swap
What harness are you trying to use? You need the F23 harness and a OBD1 conversion harness to make it simpler on yourself. Grab a P28 and chip it to run the F23
Old Jun 10, 2019 | 10:07 PM
Aradin's Avatar
Premium Member
Simplest way is actually to use the original F22 engine harness, distributor, alternator, fuel injectors, IACV, and ECU. The F22B1 ECU will run the F23 fine. Some small modifications may be needed to some wiring(extending, etc). It's a super simple and straightforward swap.
