Help identifying vtec head part
Old Jun 8, 2019 | 04:58 PM
Joey Mitchell's Avatar
Default Help identifying vtec head part
Ive found that this part is only on vtec heads, and only effects the middle vtec rocker arm. What is it and what purpose does it serve?
Old Jun 8, 2019 | 06:14 PM
Ryanthegreat1's Avatar
Default Re: Help identifying vtec head part
Lost motion assembly. Keeps the VTEC rocker in contact with the cam when not in VTEC.
Old Jun 8, 2019 | 11:10 PM
Ok makes perfect sense. Guess you wouldn't want it just flopping around in there, tapping and tearing stuff up. Thanks for the answer.
Old Jun 11, 2019 | 08:02 AM
NVturbo's Avatar
O.G. triple O.G.
Make sure you're able to press down on it with your thumb/fingers. The center section spring back up after doing so. If not, it may need replacing.
