S40/ s20 transmission build
Hello, I am new to the forums and have been doing research prior to joining and was wondering what all needed to be done to swap the fifth gear from a d16y5 transmission onto an s20 transmission. From what I read it is a direct swap, but im not exactly sure what gear(s?) it is that i need to swap over. If you can provide diagrams that would be handy. I haven't done any transmission work before so I want to be sure i know what it is that im swapping before i do it. (both transmissions are already out and ready to have the gear swapped out.
I'm sure. Y5 has a 3.722 final drive just like the Y7 hatchback and 88 CRX DX. Unless you have the corresponding engine and ECU, a longer geared trans is going to hurt more than it helps with fuel economy.
