Troubleshooting: 97 Civic does not remain. running without full throttle
Old Jun 6, 2019 | 08:38 PM
Jakob Piper's Avatar
Default Troubleshooting: 97 Civic does not remain. running without full throttle
Recently bought a 97 Honda Civic. It will only start and idle rough if you hold the gas to the floor. What could that be? Cleaned plugs and air cleaner.
Old Jun 6, 2019 | 09:12 PM
Tuopponen's Avatar
5 Year Member
Default re: Troubleshooting: 97 Civic does not remain. running without full throttle
What engine it has?
There are many things that can cause that, so it would help if you tell little bit more about the car.
Did you buy it as broken or have you already been driving it without problems?
Is there some maintenance procedures that have been done lately?
Every bit of info would be helpful here.
Old Jun 6, 2019 | 09:19 PM
Originally Posted by Tuopponen
What engine it has?
Not sure exactly on what motor it is. It’s not a vtec lol. I bought the car tonight he said it ran when he parked it 2 years ago. Went to start it and it would. It will turn over but that’s it’s. If you push the gas the whole way to the floor it idles rough that’s it. Not sure as far as maintenance goes it has sat for around 2 years.
Old Jun 6, 2019 | 10:02 PM
Tuopponen's Avatar
5 Year Member
If the gasoline in it is two years old that may cause the problems, so you could try to drain old gasoline out and fill it with new gasoline.
Old Jun 7, 2019 | 06:01 AM
muellersfan's Avatar
Default Re: Troubleshooting: 97 Civic does not remain. running without full throttle
What Civic trim?
Post pics of the engine bay.
Old Jun 7, 2019 | 12:21 PM
hondamark35's Avatar
CEL on, any stored codes?
