Possible that the wire that goes inside the car is present in the connector, but missing in the engine harness and the only thing i have to do is run a wire form the selenoid connector to the pin in the engine harness connector ?
I ended up just using a subharness to get VTEC working on my car, the ECU pinouts do not have any pins on it from the harness to engine bay plug so you'll have to route it to the interior from the engine bay
You can run it to the plugs if you know what to do, Basically go junkyard hopping for some wires. I had done this for someone before in an eg. Unfortunately his dumbass forgot and ran new wires anyways.
