Brake Light Warning in 2015 Honda Accord EXL
This is Not a brake warning light. This is the Low Tire Pressure light. You can buy a tire pressure gage from auto parts stores or walmart. Recommended tire pressures are usually listed on the drivers door jam. Check tire pressure with the gage and fill as needed.
That's the TPMS light (Tire Pressure Monitoring System).
Check that the tire pressure in all 4 tires is at 32 psi.
If one or more tire is below 32 psi, add some air and that should rectify the situation/light on the dash.
georgelimas
Mar 15, 2008 05:11 PM
