Car won’t start
Old Jun 1, 2019 | 10:46 AM
vaderman_x's Avatar
Default Car won’t start
Hi
so my 94 accord had an oil leak at the distributor and I decided to replace the o-ring, I didn’t disconnect any plug wires just the harnesses that come out of the distributor, I flipped the dIzzy on end and replaced the dried out o-ring, I reinstalled the dIzzy and now it won’t start, it cranks but doesn’t start. I did mark the distributor so I can put it back in the same position. What can be causing it not to start? Thanks
Old Jun 2, 2019 | 04:56 PM
schreps's Avatar
Default Re: Car won’t start
You may have turned the distributor shaft 180 degrees... or the connector is not plugged in properly.
Old Jun 9, 2019 | 07:00 AM
vaderman_x's Avatar
Turns out I snapped the guide bit that attaches to the cam , I replaced it and it started right up
ran it for a week and now it won’t start up again, I replaced the cap and rotor but still no start
Poedogg
Oct 3, 2017 07:38 PM
egtony
10
Sep 4, 2009 01:44 PM
mini-v-si
Mar 20, 2004 11:59 PM
