SOHC to DOHC head swap? D16Y8 to B16a, etc...
Old Nov 14, 2002 | 12:31 PM
weaselchew's Avatar
Default SOHC to DOHC head swap? D16Y8 to B16a, etc...
How feasible would it be to swap a B series head onto a D16Y8? Basically going from SOHC to DOHC... Would it require much modification? Is there much to gain from doing this? Is the B type engine plug-n-play into a D type Civic ('00 EX)? What about an H22a engine?
Old Nov 14, 2002 | 12:49 PM
LB CRX's Avatar
Default Re: SOHC to DOHC head swap? D16Y8 to B16a, etc... (weaselchew)
should i even touch this??? maybe i shouldnt have posted in the first place
shoot me now please
Old Nov 14, 2002 | 01:13 PM
Cynical 1's Avatar
Man, great way to start out posting.
Great question! Now search!
Old Nov 14, 2002 | 01:23 PM
Katman's Avatar
heh, mildly amusing newb tech question, which might get you flamed pretty hard by some people on here....but don't fret, I'll take you under my protective knowledge-wing ....
You cannot mix heads/blocks/pistons/trannys between D,B, & H-series engines. Those parts can only be mixed around within their own respective series, and only depending on what you want to do.
D-series starts off as the smallest physical engine series, then B-series physical engine parts are actually bigger than D-series, then H-series is even bigger than B-series parts. Only a few small things can be swapped around with each series, such as a majority of sensors & throttlebodies..that's about it though. You can't put a B-series head on a D-series block or vice versa, its not physically possible.
As far as your question about plug n' playing a B-series engine into a 00' civic....yes, it's plug n' play with all OEM parts (correct motor mounts, wiring harness, ecu, etc) if you know what to look for. The H-series motor(s) are not a plug n' play motor for civic/integra's; Honda didn't make the civic/integra models with an H-series motor in mind. You'll have to buy an aftermarket specialized motor mount kit for this specific swap; Hasport sells a kit. Honda made the 92-01 Civic line-up bolt n' play engine compatibility with B and D-series engines.....but not H-series. H-series is actually made on the Accord/Prelude/Acura CL platforms. Integra's are mainly built on the B-series platform, but for the 94-01 DC integra, you could actually bolt-in a D-series engine, with the respective D-series motor mounts from a 92-95 civic. Gets a little tricky..
hope this all makes sense to ya...
[Modified by Katman, 2:48 PM 11/14/2002]
Old Nov 14, 2002 | 01:43 PM
The OEMobile's Avatar
Default Re: SOHC to DOHC head swap? D16Y8 to B16a, etc... (Katman)
Hmmm.... B-series head on a D-series block, they're 2 totally different sizes, the head would have inches to spare hangin over the edge
Old Nov 14, 2002 | 02:08 PM
SOHC_MShue's Avatar
Default Re: SOHC to DOHC head swap? D16Y8 to B16a, etc... (driftinHatch)
damn if that was possible i would have already done it.
97ekbanger
Feb 18, 2013 06:21 PM
vsg1994
Oct 30, 2012 06:23 AM
Phrost
Jan 4, 2005 04:54 PM
