Fuse 23 keeps blowing please help
I have a 1990 integra with a B20b swap and just recently my fuse 23 started blowing and I have replaced it like 4 times. Sometimes it will work and last a little while and sometimes it blows pretty quickly. I thought it was some shorted out headunit wires but I cleaned them all up and the problem still persists. What are some other things I can check and where to check them? It would be pretty nice to have my blinkers and RPM gauge working consistently. I also notice I think it happens more often the hotter it is outside
Did This problem end up getting solved? I have the same issue and same b20b swap. I replace the fuse and it works till I hit my clutch to put in gear and then fuse blows. Same fuse #23
kturner2007
12
Jan 9, 2007 10:03 AM
bboyStatick
Mar 23, 2004 06:22 PM
