Best way to clean old seats in a hatchback?
Old May 29, 2019 | 01:44 AM
billybod's Avatar
Default Best way to clean old seats in a hatchback?
Best way to clean old seats in a hatchback? what tools and products did you use?
Old May 29, 2019 | 03:45 AM
LiteraCola's Avatar
Corvette Forum Member
Default Re: Best way to clean old seats in a hatchback?
I usually bust out my Bissell carpet cleaner for interior work, and it does fine. Remove the seats from the car first; this will allow easier access to the crevices and accelerate drying times. Use some regular carpet foam and let it soak into the carpet and seats for a while. Then run the carpet cleaner over it and let it dry. I have, in the past, had to use an ozone generator to eliminate really nasty interior odors. If you're a non-smoker, never buy a car from a smoker; it'll drive you mad.
Old May 29, 2019 | 01:03 PM
NukeNinja's Avatar
Remove seats, then use a pressure washer, be careful with what jet you use and don't get too close or you will make bald spots.
Old May 29, 2019 | 01:13 PM
billybod's Avatar
really? pressure washer?
Old May 29, 2019 | 01:30 PM
NukeNinja's Avatar
I have pressure washed all of my cloth and vinyl seats. Carpets too. Floor mats. They come out really nice because you can get the nasty areas near the floor and beneath. Spend extra time on stains. You just have to be careful, like I said. Get too close and you will cause damage. Lube the sliders when you are done.
The carpet cleaner sounds like a good idea too, I've just never tried it.
Old May 29, 2019 | 11:05 PM
billybod's Avatar
thanks for the tip!!
Old May 30, 2019 | 03:37 AM
LiteraCola's Avatar
I'm sure a pressure washer would definitely "get them clean", but considering these seats are 15-20+ years old, I don't know if I'd trust the foam to stay in 1 piece. Also, I'm not sure if getting water down into the mechanism of the seat is a good idea; all the "funk" is usually just embedded in the seat fabric itself. Oh well, to each his own!
Old May 30, 2019 | 05:18 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Interior detailing, we would carpet shampoo the carpet and seats, then use a wet dry vac to suck it out and leave the windows down to dry for a couple of days.
Carpet shampoo is just carpet cleaner.
https://www.thespruce.com/best-carpet-shampoos-4158201
If it's real bad, I second pulling the seats out. You can get into more spots and do a more thorough job.
SIMATIC
Oct 22, 2004 09:14 PM
cvclover
Mar 5, 2004 09:24 PM
SiZe(9)
Dec 1, 2002 01:16 AM
Vtec195hpR
Nov 27, 2002 07:33 AM
PatrickGSR94
Jul 21, 2002 11:19 AM
