Honda CR-V & Element 2WD & 4WD Element & CR-V
1998 Crv no hot start issue.
Old May 26, 2019 | 02:16 PM
Jasonvan's Avatar
Default 1998 Crv no hot start issue.
Have a 98 crv with 200k km.
the car starts no issue when it’s cold. However when it is hot, it does not start. Just keeps cranking. I do smell gas after a while of cranking.
i have already replaced
entire distributor ( includes new internals)
spark plugs and wires from NGK
main relay
fuel pump
fuel filter
cleaned out the sensors in the intake
cleaned out throttle body
if I do let it sit for a hour cold it will start up fine. Pulling my head on what it could be. When it does start it isles fine and drives fine
Old May 27, 2019 | 08:50 AM
ThisIsMatt's Avatar
Default Re: 1998 Crv no hot start issue.
Where did you get your distributor? A lot of these "loaded distributors" that come complete are filled with cheap, Chinese garbage electricals. The ignition module is the main culprit when this failure mode occurs, and if you replaced yours with a non-Honda one you may still have issues. Check for spark at the plugs when you're experiencing the failure. If you have no spark, I'd look for a known-good ignition module (of Honda origin), and see if that fixes your issue.
dsettlemoir
May 7, 2016 03:34 AM
95PreludeJDM
Nov 29, 2010 06:20 PM
CRXherbie91
May 14, 2008 05:49 AM
vheissu
Nov 6, 2005 06:10 PM
