Honda CR-V & Element 2WD & 4WD Element & CR-V
2000 Honda CR-V crank no start
Old May 26, 2019 | 06:46 AM
Crvguy859's Avatar
Default 2000 Honda CR-V crank no start
Hi I’m new to the site I have a Honda CR-V that run extremely well but recently on two occasions I’ve got in it and it will crank but won’t start I have had it the shop and we can’t figure out what’s wrong Heres what’s been replaced in the last year
new timing belt kit and water pump
new spark plugs and wires
new fuel pump
new clutch
all new belts
new exhaust
new battery
also today I was driving it home and all of a sudden my gauges just started going down and it stopped on me had to pull to the side I have no idea what it could be any advice would be appreciated thanks
Old May 26, 2019 | 02:28 PM
Jasonvan's Avatar
Default Re: 2000 Honda CR-V crank no start
Could it be a loose ground somewhere. Fuel filter?
Old May 27, 2019 | 08:45 AM
ThisIsMatt's Avatar
It is extremely common in this scenario that your ignition module has failed. The module is a small metal box mounted under the distributor cap that controls when to send a spark. As they age, the solder joints in the modules develop cracks and eventually when the modules heat up under use, the solder cracks render them inoperable. You'll find reports of this all over this forum and online in general. The failure mode is generally stalling followed by a no-start when the vehicle is at operating temperature, and perfect running conditions when the vehicle has not yet warmed up. If when you're experiencing the failure you check for spark at the plugs and find that there is none, more than likely you're in the market for a new ignition module. You'll find these modules all over the internet for cheap (20-40 bucks USD), but they're China-sourced garbage and if you get 15k miles out of them before they start failing again I'd be surprised. If you have the time to wait for it, your best bet is to source a Honda unit off Ebay. I replaced the module in my 2001 as a preventative measure at 150k miles with a brand new Honda unit I bought off Ebay for 82 bucks USD, which was a particularly good find.
Check out whether you have spark at the plugs during a failure, and if not pick up a module.
Old Jun 9, 2019 | 05:44 AM
SFreeman's Avatar
What @ThisIsMatt suggested is likely right on. My 2000, did this exact same thing, about 3 months ago. Checking spark to the plugs will narrow down the issue.
Old Jun 9, 2019 | 06:55 AM
Ryanthegreat1's Avatar
Don't rule out the main relay. They will fail at the solder joints as well and cause a crank no start condition.
Old Jun 9, 2019 | 09:52 AM
ThisIsMatt's Avatar
This is true about the main relay, and they also present a similar failure condition (stalling/no-start at operating temp, proper operation when cold), but the main relay supplies both the ignition system AND the fuel system with power. If you're diagnosing the failure while the issue is presenting itself and you find proper fuel pressure, your main relay is fine (or at least not acting up at the moment). If you find lack of spark AND fuel, solid chance it's a main relay.
Old Jun 9, 2019 | 10:19 AM
Wait you lost all electrical power and the gauges dropped to zero? Could be the ignition switch.
Old Jun 10, 2019 | 12:50 PM
sf340b's Avatar
5 Year Member
This .
MintyCivic
Mar 6, 2016 03:52 PM
cephas41
Mar 23, 2013 01:38 PM
RufusHonda
Oct 6, 2012 12:21 AM
NateRhodes
Jan 26, 2012 06:50 AM
joblow
Feb 20, 2003 09:18 AM
