If I plug an H23A1 ECU into my 93 accord....
it will do the same damn thing that my accord did when I plugged an H23a1 ecu in:
Start, Rev, No codes thrown, but it will choke at idle and stall.
is that because it's not getting enough fuel due to the accord smaller injectors? Cause i have the H23A1 injectors too - got the whole motor home finally and was just curious if it'd work.
The CEL came on, I'm gonna try putting in the lude injectors in the morning. The CEL only comes on after I get up to 80km/h, I'm guessing it wants more fuel. My mechanic think this is probly the case as well. The engine pulls pretty hard all the way 7000rpm now
Well, for a stock f22a6 anyway.
[Modified by psyphre, 6:57 PM 11/14/2002]
Well, for a stock f22a6 anyway.[Modified by psyphre, 6:57 PM 11/14/2002]
CEL came on, no big deal though, it's just looking for the Ludes knock sensor.
Car is deffinetly faster though, there is a hill near my house and if i give it all she's got I'm doing 125km/h at the top, now i'm up to 132ish. plus there's an extra 60lbs in the trunk right now.
[Modified by psyphre, 3:57 PM 11/15/2002]
if you get the H23 ecu programed to eliminate the knock sensor then yes it will pull a little harder then your accord. good luck
Yeah but then what do i do when i put the H23 in the car next year? get the ECU re-reprogrammed?
I do shift at 7k
Burning oil with 292,000kms and yet I still shift at 7k. Too bad the 2nd gear synchro was mess when i got the car cause you have to be really careful on the 1-2 shift at 7k.
I do shift at 7k
I do shift at 7k
I do shift at 7k
koreachangsu
Sep 13, 2006 07:38 PM
