Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2005 Honda Civiv new ignition switch crank no start
Old May 14, 2019 | 08:01 PM
Lockholder's Avatar
Default 2005 Honda Civiv new ignition switch crank no start
My ignition switch cylinder went out on me so i pulled a used one that was good from another 05 and installed it and now it'll crank but it won't start, i heard i may have to get the key reprogrammed. is there any other way around this?
Old May 19, 2019 | 05:45 AM
hondandy's Avatar
Default Re: 2005 Honda Civiv new ignition switch crank no start
You didn't replace only the lock cylinder. You also effected the anti-theft system (immobilizer). Box the original key.
Old May 19, 2019 | 05:47 AM
Lockholder's Avatar
And let me guess, no way around that? Sorry I only know about 7.3 powerstrokes NOTHING on Hondas 😂
Old May 19, 2019 | 06:17 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
If you don't want to reprogram the immobilizer system.
1. Install the original immobilizer unit back.
2. Either (a) tape the original key to the replacement key or (b) tape the original key inside inside the plastic steering wheel cover to hide it and forget about it. The Immobilizer won't function as a theft deterrent; but you save money.
Old May 19, 2019 | 06:23 AM
Lockholder's Avatar
So I swapped that over and held the key to the “new” key and tried turning over and it just cranks. Now there is a CPS code and the car has been struggling here and there. Could it finally have gone out as well to add to the immobilizer? This trick with the key how successful is it? Should it work if I did it? Because if I did it and it didn’t work then it’ll be the CPS correct?
sorry for it being lengthy. I have a CPS on hand.
Old May 26, 2019 | 06:32 AM
hondandy's Avatar
Don't do it like that. You don't want two chip keys there. Do it like I explained in this post.
https://honda-tech.com/forums/honda-...p-way-3334578/
The idea is to make the ecm think everything is cool and the car is not being stolen (broken steering column)
Old May 26, 2019 | 06:34 AM
hondandy's Avatar
Also if you could remove the chip from the key and put it into a ilco replacement key that will work.
Old May 26, 2019 | 08:34 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
How about this:
Unplug the new immobilizer, plug in the original immobilizer with your original key taped to the ring... and tuck it somewhere out of the way. This way your ECU still "sees" the original key that is paired with it and the new key will crank the car. This will effectively negate the security benefit of the system, but at least you can drive the car until you can afford to get the new key programmed to match the ECU.
mechan-chick
Feb 8, 2017 08:46 PM
Korisaurusrex
Nov 3, 2014 09:56 PM
fecooper
Audio / Security / Video
Aug 11, 2012 10:59 AM
1sikhatch
Apr 8, 2010 08:58 AM
GoldCoin
Oct 24, 2007 12:09 AM
