At my wits end. 1990 accord ex f22a4 engine not cooperating
About a month ago I bought a 1990 Honda Accord EX f22a4 from a shady fellow. I have had nothing but problems the whole time I've owned it, with such as fit valve, IAC valve, replaceing throttle body, and all sorts of hoses and miscellaneous s*** I have done to it as well. I finally got the wandering idle problem under control. Now it still idles pretty rough. I used my manual to determine that it could possibly be the map sensor giving me problems. I put a multimeter on it today n got it narrowed down to the white blue wire having an open or shorted connection, or replace the ecu. The wire tested fine so i went down to pick apart n picked up a used ecu. Things got pretty out of wack. The idle was still rough at opperating temperature, but upon deceleration, the engine bogs from 1500 rpm to 1000 rpm for a second or two then right back up to normal. Its emniting a horrible odor that smells like sulfur n it sometimes smells of gas. Also my gas mileage is horrible. Its burning through the gas for sure. I stopped off at the gas station to fill up as i was on a quarter tank n wen I opened my fuel cap fumes came hissing out of there for about 8-10 seconds. Wen i tried pumping the gas into my tank the nossle for the gas kept closing. It was all i could do to get 4 gallons in, n it stopped five or six times. I had to put it in as slow as i could go to get it in the tank. Has anybody experienced such symptoms, or have a guess at wat could be causing this nonsense. Any help would be appreciated very much!! Tia!!
Sorry to hear about all of the issues, these cars/engines are usually pretty simple and straight forward, not to mention bullet-proof... but they are getting pretty old so if they weren't well maintained you can pretty quickly wind up being the one picking up all that slack. Hopefully once you get this issue sorted it'll be the last one you have for awhile. Anyway, let's get to the issue at hand... it sounds to me like it could be a bad fuel pressure regulator and/or check-valve; possibly even the return-valve? These parts just go bad after 20+yrs and they're not on the list of things we think of replacing while doing general maintenance. Also, have you considered draining and flushing the fuel tank completely? You could just have some nastiness in the tank/fuel system? The fuel pump is very easy to get to as is the fpr so I'd start there. GL and I don't log in very often these days but I'll check in over the next few days and try to help you out as much as I can.
Tank is over-pressurized and the EVAP system may not be working correctly, have you verified correct functionality of the EVAP system? This would also artificially raise fuel pressure as tank pressure would push against returning fuel if the duckbill valve was missing. Pull the EVAP line off the charcoal canister and make sure it is not full of fuel nor the canister is full of fuel.
This would cause a rich running condition, run too long like this could damage the cylinder walls from washdown, and it would overheat the catalyst as it is not designed to burn raw fuel, which would cause the stink and horrid fuel mileage.
Does your CEL lamp work? Turn the key to II(ON) and it should come on during proveout. Check for any stored codes.
Do you have a voltmeter? Can you back probe the connector to the O2S and monitor voltage? Max voltage will be about .9V, lowest will be .1. Ideally the voltage should be switching from about .3 to .6, hitting lean/rich flags. If the readout is pegged or barely moving then the O2s is either damaged or the engine is running rich.
for the sake of having the full picture, have you done any checks on the engine mechanicals (valve timing and lash adjustment, compression check)?
quick story: once worked on an Integra with odd drivability issues that had gone from shop to shop including the local Acura dealer, and no one could get it right. it wasn't until after we found the rocker assembly had been put together wrong that the owner mentioned the head had been rebuilt recently.
There are three ports on your charcoal canister, IIRC.
One goes to the tank, This should be a single line and probably has a 'two way valve' that is between it and the main tank vent line. Can't recall if that is inside the 'control box'. Just follow the line.
There will be a mini diaphragm(purge control) on the top of the charcoal canister with two more vacuum ports.
Lower below the diaphragm(purge control) port should go straight to the throttle body port that is BEFORE the throttle blade. This should be on the atmospheric side of the butterfly, not on the vacuum side. You don't want it pulling vacuum.
Upper port on top of the diaphragm(purge control) should have a vacuum line that goes to a purge control solenoid(electrically controlled), possibly mounted int eh 'control box', and then another line from the solenoid to the intake manifold plenum(vacuum side)
If any of the above lines are connected incorrectly, there may be fuel inadvertently pulled into the EVAP system.
This system provides a controlled air flow to prevent fuel vapor from escaping(emissions) and to allow the tank to maintain correct pressure so as not to create a vacuum in the tank(preventing fuel flow) or pressurization(causing over pressure in the system).
If any of this system is non functional or working incorrectly, you could cause fuel to be sucked into the charcoal canister and cause pressurization of the tank, which would lead to too much fuel pressure.
Pull all the hoses going to the charcoal canister, verify they are going to the correct locations, and verify they do not have any liquid fuel in them.
They will smell like fuel vapor as the charcoal canister does absorb these gasses to be later re-burned during normal operation.
There should be a two way check valve between the charcoal canister and the EVAP tank line. This should allow vapor/gases to pass through to and from the tank/canister but should prevent liquid fuel from passing through. IIRC.
The Fuel Pressure Regulator, mounted on the fuel rail, will mechanically be forced open beyond 43PSI. Basically there is no control to close it, and if pressure in the tank is higher than that there is nothing that the FPR can do. Now if hte FPR itself is somehow jammed closed it could cause an over pressure issue, but I doubt it has anything to do with the current issue.
BTW the duckbill valve is located on the end of the fuel return inside the tank, or there should be. It just controls the flow of fuel returning to the tank and is to prevent backflow of fuel into the return line. It's a checkvalve. Usually on older cars the valve has blown off, deteriorated, or just not there. Usually new fuel pump assemblies(not just pump motors) will have it installed. Although sometimes not. I though Honda's used em, but I could be mistaken.
Brendan Missel
May 18, 2017 02:56 PM
Draken Wolfe
Sep 27, 2013 03:05 AM
