Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Connecting rod nut thread
Old May 12, 2019 | 05:38 PM
musically lucid's Avatar
Default Connecting rod nut thread
Hi, this is my first post
I am doing some work on my civic replacing bearings because of rod knock and have lost two of the connecting rod nuts on my 03 Honda civic ex part number 13205-634-010. I'm trying to figure out the thread size on it so that I might be able to find a cheap replacement in my area but it seems to be smaller threading than anywhere I've checked so far carries.
Hopefully I can get an answer soon
Old May 12, 2019 | 08:44 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Connecting rod nut thread
So, you aren't willing to spend $9 to fix your car ??? SERIOUSLY ??? Even if you could find a replacement nut at your local hardware store or nut-and-bolt house... what do you think your chances are of finding something with the proper engagement surface and the same (or stronger) material composition ???
I am not sure the exact size, but I believe it is either 9mm or 11mm x 1.0 pitch.
Old May 12, 2019 | 08:49 PM
Its not that I'm not willing to spend that much its that I cant find anything local that has it in stock and I'm trying to get it fixed asap
Old May 12, 2019 | 09:24 PM
JRCivic1's Avatar
10 Year Member
Community Builder
These were your words, not mine. What about a salvage yard where you could rob a couple of nuts from an existing engine then ???
Old May 13, 2019 | 01:45 PM
stin1's Avatar
Loved
Community Favorite
Do NOT use hardware bolts. The grade won't be the same. From my experience, my Honda dealer will have them the next day .
TracerAcer2.2L
Welding / Fabrication
Sep 18, 2015 10:44 AM
DesEM2
Apr 26, 2012 02:00 PM
steplauna
Mar 11, 2010 09:59 AM
97grnrs
May 8, 2007 07:21 PM
bbrian
May 10, 2005 08:39 PM
