5th gen manual/ base h22a4 need transmission swap nfo
Hello Community,
ive had 5th gen preludes for years now, and between them all have rebuilt just about every component on them including the engine ...everything except the transmission.
i was was at the junkyard the other day and almost pulled an m2u4 on accident...then I realized it had atts.
oops, it’s an SH tranny that would’ve NOT bolted on.
apparently, after doing research, accords manuals will bolt directly on. But I found a write up saying the newer year f23’s will bolt up but I’d need matching accord axles to prevent the axles from being too long?
(I’m not worried about losing the quickness, as this is a daily driver and the taller gears will help on the highway...I have a race car for my quickness needs)
My question: are the f22 accord trannies direct bolt-ons wherein I can reuse my prelude axles?
If so, what year/model accords can I pull from???
ALSO, I need to know which shifter cable set to use!
thanks in advance,
Henry
thanks in advance,
Henry
bb_one
Apr 20, 2005 10:58 AM
