Is it normal to actually have a leak in the Rack & pinion Assembly?!
Old Apr 17, 2019 | 08:14 AM
ollie1248's Avatar
Default Is it normal to actually have a leak in the Rack & pinion Assembly?!
Am I right on this one? I know it’s power steering but is it coming from the rack and pinion? I’m new so any help would be greatly appreciated!
Old Apr 17, 2019 | 09:48 AM
DumpdEJ6's Avatar
I like the tuna here
Default re: Is it normal to actually have a leak in the Rack & pinion Assembly?!
If you have leaks from your rack and pinion, you'll either need to rebuild it or get one that is good. If it's coming from the rubber boots, then the seals that are leaking are inside the rack.
Old Apr 17, 2019 | 02:42 PM
ollie1248's Avatar
Thanks, curious, did the video show up on the thread?
Old Apr 18, 2019 | 03:56 AM
DumpdEJ6's Avatar
No it didn't.
THarr555
Nov 28, 2017 09:45 AM
ChalmersP
Honda CR-V & Element
18
Sep 30, 2017 12:29 PM
VTEC junky
Suspension & Brakes
May 26, 2013 10:48 AM
mflannery1980
Feb 24, 2012 10:03 AM
iblandford
Jul 26, 2009 10:06 PM
