Rsx type s shifting problems
Old Apr 12, 2019 | 01:20 AM
AllDay-DB8's Avatar
Default Rsx type s shifting problems
Hey guys thanks for taking time and reading this post. Ok first in my way home from work I was pushing the car a little in the back roads. When I slow down in to town. I hear a grinding noise when I when in to second. In my next light I put on first let the clutch pedal go and it grind and push the gear back. So I hold the shifter in first let the pedal go and push back but it stay in first and I make home. I smell some clutch burning like 1 ago I don’t drive the car that much but I remember and I when ahead and replace the clutch. With a exedy oem replacement. Now the car is doing the same I have to push the shifter and hold on there so it won’t come out of gear. I didn’t drive to check the other gears. It was late when I finish and found out is not right. So I just left for today after work. Thank you for the help guys and sorry if my English is not the best.
Old Apr 12, 2019 | 01:25 AM
AllDay-DB8's Avatar
Default Re: Rsx type s shifting problems
I forget to say the clutch was bad and the ring that go in to the flywheels wasn’t line up like it would be new it was bent
Old Apr 12, 2019 | 07:45 AM
AllDay-DB8's Avatar
I test drive it today and I can get get out on second gear. But not in first only if I push the shifter and hold there and release the clutch really slow. And I can get in reverse no problem either
Old Jul 7, 2019 | 03:45 PM
SilverMidge04's Avatar
Will it shift into anything higher than second gear?
93delslow315
Feb 5, 2010 07:08 AM
slowdaintegra
Dec 21, 2005 01:31 PM
Utilitarian
Jun 17, 2005 10:08 AM
