Hello, Im looking for some rim inserts for my si rims, all the rims except one has them. I went to the local rim shop and they had larger inserts and they said they dont use smaller size so they wouldnt order me four (I guess the order has to be a minimum of 1000pcs). Does anyone know were I can purchase these and what size they are? Any help is highly appreciated!. This is missing the inserts. This one has the inserts. I found this online but as you can see they're minimum purchase is 1000pcs.
Thanks for the info. I believe this is for the emblem cap, I'm looking for the insert that goes in the rim were the lug bolt protrudes were the actual lug nut tightens down onto.
Gotcha. If you can pop one out of the other wheels and take measurements, try this site Wheel Inserts
