molested b swapped 98 civic need help
Old Apr 7, 2019 | 08:44 PM
fa5honda_boi's Avatar
Default molested b swapped 98 civic need help
okay so. I picked up a 98 dx that has a b20 bottom end and b18b head. it's running off of a 94 Integra computer and it looks to be obd2 converted. Im completely unsure which wiring harness was used but Im kinda thinking they used the teggy harness. so the Speedo doesn't work. and they failed trying to wire in the filling fan. the vss in the tranny is a 2 wire and so is the connector on the other end. which is why I think it's the b18 harness. I'm really not trying to swap out the whole harness as seeing that everything else works and I can always wire in the fan on a manual switch. so would swapping out the cluster for the Integra cluster work? would any of the wiring have to be switched around if so? this is the first car I've had with a B series and im honestly just looking to re sell it.
jimlaH
K Series
Jul 23, 2012 11:10 PM
navin
14
Mar 10, 2003 12:16 AM
ef ect
Jan 8, 2003 05:05 PM
sytema
Nov 12, 2002 08:12 PM
