where does this hook up~!
Old Nov 14, 2002 | 08:47 AM
metal-x's Avatar
Default where does this hook up~!
Old Nov 14, 2002 | 09:16 AM
hondaeg5's Avatar
Default Re: where does this hook up~! (metal-x)
1st pic is the pcv. it goes to the mani. 2nd is for the secondary butterflies. if you do a search there is a good archive topic in how to install a skunk 2 mani. you most likely will find all your answers there. good luck
Old Nov 14, 2002 | 09:26 AM
Katman's Avatar
Default Re: where does this hook up~! (hondaeg5)
....and that skunk2 manifold intall link is here:
http://tiiite.ghettoracer.com/tech/sk2manifold/
this will show where the PCV valve is plugged into.
The dashpot vaccum tube should be plugged into a small vacuum port that should be available on the GSR intake manifold somwhere....
Old Nov 14, 2002 | 09:57 AM
metal-x's Avatar
Default Re: where does this hook up~! (Katman)
thanks guys,
that was a very helpful link
so on my gsr it would mount in here?
[Modified by metal-x, 11:19 AM 11/14/2002]
Old Nov 14, 2002 | 12:21 PM
metal-x's Avatar
ttt
marshallbj
Apr 12, 2008 09:44 AM
marshallbj
May 17, 2007 09:30 AM
master honda tech
Apr 24, 2005 02:58 PM
spooncivic1
Apr 6, 2005 01:11 PM
Vteg02
Aug 15, 2001 07:43 PM
