clutch master cylinder
Old Nov 14, 2002 | 08:14 AM
SupaTegRS's Avatar
Default clutch master cylinder
Well, my car has had troulbe getting into first and second gear lately. Its been getting progressively worse. So last night, I checked under the dash and sure enough, my clutch master cylinder is starting to leak pretty bad.
My question is this....do I need to get an OEM cylinder? I know Acura would charge an arm and a leg for it. I found one on nopi that is made by Tokico...cost is ~50 bucks. Just wanted to know if this would work ok, or if I should just fork over the extra money for the real thing.
Also, do I need to replace the slave cylinder at the same time? Or can I leave that one alone and just change the master?
Thanks,
SupaTeg
[Modified by SupaTegRS, 5:31 PM 11/14/2002]
Old Nov 14, 2002 | 11:29 AM
SupaTegRS's Avatar
Default Re: clutch master cylinder (SupaTegRS)
anyone? I kinda need to get this taken care of soon.....
Old Nov 14, 2002 | 01:42 PM
b18bfreak's Avatar
Get the oem part if you have the extra $.
Old Nov 15, 2002 | 07:41 AM
dwolsten's Avatar
Go to your local auto parts store and get it. I went to Checker Auto and got one, and it was the same as OEM, brand new. The guy told me that for the clutch master cylinders, they just sell OEM ones because they're so inexpensive and it's not worth it to remanufacture them. And of course, they're much cheaper than the dealer; I believe mine was like $70.
Old Nov 15, 2002 | 09:08 AM
IC x Prince's Avatar
New User
Default Re: clutch master cylinder (dwolsten)
I have one too. It seems to work pretty good. I just wished I had the OEM part just for peace of mind, but oh well...I need it that day.
Old Nov 15, 2002 | 09:10 AM
New User
Thanks,
SupaTeg
I dont' think you need to change the slave cylinder unless it's broken. I replaced mine cuz it was. but that was an aftermarket part aswell.
Old Nov 15, 2002 | 09:24 AM
SupaTegRS's Avatar
Default Re: clutch master cylinder (UltraGSR)
thanks for the help, guys
Old Nov 15, 2002 | 01:04 PM
junglistgsr's Avatar
its a good idea to lube the slave cylinder up after you replace the master cylinder since you'll be down there bleeding it anyway. all you have to do is take off two easy bolts and the slave cylinder slides out, you can lube it up without removing the fluid line into it.
Defcon2030
Dec 21, 2006 11:17 AM
4175017
Sep 22, 2006 10:37 AM
Elfstone
Jan 11, 2006 10:20 AM
digital sol
184
Oct 30, 2005 01:49 PM
PatrickGSR94
Nov 9, 2004 07:22 AM
