1998 coupe with Single cam vetch Turbo
Old Mar 17, 2019 | 08:52 AM
GamingDaD Grim's Avatar
Default 1998 coupe with Single cam vetch Turbo
Somebody please help me out I got a 1998 Honda Civic single Cam vetch I have 450 cc injector And I’m running 10 pound boost Do I need A resistor box and how Do I wire it
Old Mar 17, 2019 | 08:53 AM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Default Re: 1998 coupe with Single cam vetch Turbo
That depends on the type of injectors you have.
Old Mar 17, 2019 | 08:55 AM
THey say 450 there from the eagle talon
Old Mar 17, 2019 | 01:42 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
If they are DSM injectors... you will need a resistor box. You will need to de-pin the four yellow/black wires that correspond with the fuel injector plugs from the distribution plug under the intake manifold. Then use a '92-96 Prelude or Accord resistor box and insert the injector wires into an appropriate plug that connects to the resistor box. The single red wire from the resistor box needs to be connected to the distribution plug and then you are done.
Old Mar 18, 2019 | 04:03 AM
thank you
Rasmusm
Apr 19, 2014 06:10 AM
myessay
Oct 27, 2011 11:42 AM
93grayeg
Jan 24, 2011 04:42 AM
JBk24crx
Oct 24, 2003 12:43 AM
tvrsir
Oct 9, 2003 06:52 PM
