Front fork shock absorber difference EG EK
Old Mar 12, 2019 | 11:26 AM
kris29's Avatar
Default Front fork shock absorber difference EG EK
=leftHello, I am looking for information what are the differences between the front forks of EK shock absorbers and EG the fixing diameter and the same? Thank you
Old Mar 12, 2019 | 11:54 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Front fork shock absorber difference EG EK
same...only the rear LCAs are different width (must use spacers to compensate)
Old Mar 12, 2019 | 01:09 PM
kris29's Avatar
=leftthank you for the confirmation that's what I thought too
Old Mar 12, 2019 | 01:57 PM
Chrisfrom1986's Avatar
What spacers change the fact that they are significantly different lengths?
Old Mar 12, 2019 | 03:47 PM
hybridnorth's Avatar
Spacers are for the shock bushing, ek is roughly 10mm thinner than eg/dc. It has nothing to do with the length of the lca in this case.
Side note 99-00 SI front forks are wider as well since they use a tubular lower control arm.
Old Mar 12, 2019 | 05:13 PM
NVturbo's Avatar
O.G. triple O.G.
width, not length.
From what I recall, when I bought my Progress coilovers, it came with 4 spacers for the rear LCA. If you have a '96-00 Civic, you will need to use them because the LCA is not as thick as the 92-95 Civic's. Spacers are for the lower portion of the damper to the LCA.
L1lKraYzi3
Suspension & Brakes
May 30, 2013 10:33 AM
BrianFreels
May 4, 2009 01:36 PM
1 jonesie
May 20, 2007 05:08 PM
RHDintegXsi
Suspension & Brakes
Mar 11, 2005 08:38 PM
