06 element bypass oil pressure switch
So i have had gone down the list of possible fixes related to rocker control arm/ vtech solenoid/ oil pressure switch to know avail. I have taken it into the Honda dealer numerous times and still is not fixed. I've had it with the switch so I am turning to you Honda Gearheads for answers or suggestions. Is it possible to bypass the Vtec solenoid and if so what consequences would I expect? And if one could point in the direction as to how this could be done. Not looking for a miracle but it seems like it should be totally doable. Hopefully there's some buddy out there that has already done this maybe it's a common thing to do or maybe I'm just crazy would love some help.
Why would you want to ? Having VTEC related issues? Common problem on the K series especially if oil isnt changed regularly.What symptoms are you having? Any check engine codes?
white90rexsi
Jul 3, 2007 10:08 AM
