Ej6 Hatch K Swap (EK hatch)
Hello I have a 1998 Civic hatchback and it currently has a d16y7 as many of you probably already know I have always wanted to swap the old single jingle for something with more power, I wanted to ask yall what exactly would my parts list look like if I wanted to go for a budget K swap on my ej6.
All information would be appreciated thanks!
See if you can find a wrecked car (preferably wrecked in the rear) to buy that came with a K series and manual transmission. That way, you get:
Engine
Transmission
Shifter box & cables
Clutch/flywheel
Intermediate shaft
starter
ECU
Immobilizer & key
Alternator and other accessories
Then all you’ll need are:
Axles
Mounts
Header (unless you want to heat and bend the oem one)
Fuel pump
Fuel pressure regulator (maybe)
Engine
Transmission
Clutch/flywheel
Intermediate shaft
starter
ECU
Immobilizer & key
Axles
Mounts
Fuel pump
ekhonda
Apr 16, 2007 07:25 PM
louie3252
Aug 24, 2006 06:18 PM
