What is this part called ... noticed leak came from here
What bolt or part number would this be???
So I took apart my intake and noticed a bolt missing in the head... looks scary like oil can leak. Please help
The leaking oil is coming from the corner of the cylinder head and not the empty threaded hole in your pic. Either the valve cover gasket is leaking at the corner OR the #5 cam bridge/cap has been removed at some point and not properly resealed when reinstalled. Messy... yes. A Danger... nope.
The bolt that goes in that hole originally held a bracket in place... a bracket that located the OE air box.
