93 civic hatch Replacement hood isn't lining up correctly
Old Feb 15, 2019 | 05:31 PM
Chev's Avatar
Default 93 civic hatch Replacement hood isn't lining up correctly
Hello, I recently went to the junkyard and pulled a replacement hood for my hatch, and it's misaligned at the sides and the front between the bumper. I don't have a picture with me, but the hood is too close to the driver side, and it has a finger size gap in the front when it's completely shut. I tried adjusting it from the hinges, but I can only move it up and down, not side to side. Am I suppose to adjust it from the hood to the hinge, or from the hinge to the body of the car. Also, the latch part of the hood when I got it was slightly bent, but I hammered it back into place. (Just in case you need that information.)
Old Feb 15, 2019 | 05:48 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: 93 civic hatch Replacement hood isn't lining up correctly
if your car is out of align, it doesn't matter which hood you use, it will still be off. If the hood was fine on the donor car and yours didn't fit...what does that tell you?
Old Feb 15, 2019 | 05:57 PM
Chev's Avatar
The original hood on the car fit fine, I replaced it because their was a dent when I guess someone dropped the hood with the hood prop in the wrong place.
Old Feb 16, 2019 | 10:10 AM
triple beam's Avatar
10 Year Member
sadsfasdfsdfasdfadsf
Old Feb 16, 2019 | 10:15 AM
10 Year Member
1. i would recommend getting a hinge thats not bent.
2. you can adjust the fenders side to side. take off four 10mm bolts on top i believe
3. the hinge has 4 bolts, upper part and lower part can be adjusted slightly
i would slide the fenders out as much as possible to the very end, then slight the hood all the way to very front. then start adjusting from there to your liking.
Old Feb 16, 2019 | 10:25 AM
Chev's Avatar
I'm sorry, I didn't mean the hinge was bent, the hook part on the hood that goes into the latch was bent slightly, but I hammered it back and it looks straight, but I should probably take a level to it.
I will give that a shot when I get home, can the front latch be adjusted at all to lower the gap between the hood and the bumper?
Old Feb 16, 2019 | 11:44 AM
mk378's Avatar
If you loosen the hood to hinge attachment on one side and pull it forward or backward, the most noticable effect is the front of the hood moves from side to side (the whole hood pivots).
Carpoollane
15
Jan 23, 2017 06:05 AM
BlackCivicEX
Nov 14, 2016 06:04 PM
H22CIVICJDM
Jan 21, 2007 06:19 PM
ef9robert
Aug 2, 2005 07:57 PM
Pants
Aug 12, 2002 11:19 AM
