please help discuss what going wrong
Hello all, firstly , i am sorry for my english is not good.
I just finish the engine assemble and got the first starting.
Because of i changed a oil pump there is no crank position marking on the oil pump, so , i just use the tools to feel the #1 piston in TDC to place the timing belt. in fact , may be i really placed little incorrect timing belt(may be just one teeth)
after that, i do the compression test , there are average low around 12X PSI, may i know is it all cylinder get average low compression because of the timing belt? If Yes, how can i get the right alignment with out the mark on the oil pump?
I have inspected all the valvetrain , there are no one sink.
Thanks for help
Thanks for help
Likely timing is off. I don't have a timing cover on my setup and it's not that hard to set TDC. Just line up the last mark on the crank pulley to the center of the timing belt tensioner. If you look at the bolt from an angle, the CP mark will be in the middle of the bolt. This is on a D16y8 motor by the way
What motor setup are you working on??
I will try to place the timing belt again,
Thank you for the help.
i have place the timing belt again and its can start.
but i am confusing do i place it right prefectly. because if i put two of tools to in the cam hole, but there are two of cam gears have one or half teeth retard. If i turn the cam gear "up" in up position , then, the middle groove is not face to another one.
https://ibb.co/VDpZqGQ <<<<the link to the photo
VTgringo
Aug 11, 2004 03:47 PM
PM-Performance
Jun 3, 2004 04:51 PM
