d16a1 pistons + d16a6 motor + boost = ?
Old Nov 13, 2002 | 11:16 PM
Rydaddy's Avatar
Default d16a1 pistons + d16a6 motor + boost = ?
Would the compression of a d16a6 block with a1 pistons be too high to safely boost for a daily driven car on pump gas? I would run around 5-6 psi daily and probably more at the track wiht the Greddy kit + type 24 intercooler. Thanks....
Old Nov 14, 2002 | 02:43 AM
smashed4thgen's Avatar
Default Re: d16a1 pistons + d16a6 motor + boost = ? (Rydaddy)
naah way to hight the a1 pistons would give u a high compression
Old Nov 14, 2002 | 07:33 AM
Sonny's Avatar
You're looking at about 10.8:1 with the 88-89 A1 pistons (it will be a touch less with 86-87 A1 pistons), the stock A6 headgasket, and A6 head.
People have boosted 11:1 engines before, but your margin for error will be very small.
Sonny
Old Nov 14, 2002 | 07:36 AM
Spade's Avatar
Street fine. Track. HELL NO. I wouldn't do it.
Ref: SCC turbo'ed the 11.5:1 Toyota Matrix but, 7 psi and A LOT of tuning.
Old Nov 14, 2002 | 02:14 PM
Rydaddy's Avatar
Default Re: d16a1 pistons + d16a6 motor + boost = ? (Spade)
So I would be looking at 10.8:1 compression with the a1 pistons in the a6 motor? In order to avoid detonation fuel tuning is involved right? As long as I have the correct fuel management goodies and use 91 octane I should be fine for street? The reason I ask this question is because I want to build up my old a6 and drive it N/A for a while until I can afford the Greddy kit .
Old Nov 14, 2002 | 02:32 PM
Spade's Avatar
Just get a Final Drive kit and an LSD.
Old Nov 14, 2002 | 03:27 PM
Rydaddy's Avatar
I was looking at a ZC tranny and swapping my Si final drive into the ZC. That a good move? Or should I get a different FD....suggestions?
Old Nov 14, 2002 | 07:59 PM
Wazup's Avatar
srr 4.9 fd, well, if u choose the all motor route.. anyway... i didnt know that the a1 pistons give an a6 10.8 c/r? cool, so what kind of comp would they give a y7 with a 34.6 cc chamber? maybe around mid 11? i hope..
Old Nov 14, 2002 | 10:54 PM
Rydaddy's Avatar
Default Re: d16a1 pistons + d16a6 motor + boost = ? (Wazup)
ttt
Old Nov 14, 2002 | 11:13 PM
PyroVTEC's Avatar
New User
... and SCC blew the Matrix's motor! Oops!
Old Nov 15, 2002 | 09:27 AM
Spade's Avatar
Default Re: d16a1 pistons + d16a6 motor + boost = ? (PyroVTEC)
LOL when did that happen
Old Nov 15, 2002 | 11:18 AM
PyroVTEC's Avatar
New User
I think it was in one of the past two issues... you'll have to check... so sad though!
Old Nov 15, 2002 | 02:52 PM
Rydaddy's Avatar
That's a little worrisome! If I am planning on going FI in the future, should I just replace the pistons with new a6 pistons? My motor has 160,000mi on it, but it still runs strong. What all should I replace if I want to make it able to take 6-8 psi daily? Or would it just be more cost-effective to spring for a low mileage d16z6....Spade where you at
Old Nov 15, 2002 | 03:15 PM
Spade's Avatar
You should just replace your rings and bearings, use your existing pistons. They will be fine.
Orange City. Southern Cali.
[Modified by Spade, 4:16 PM 11/15/2002]
Old Nov 15, 2002 | 04:12 PM
Rydaddy's Avatar
What about valvetrain-wise? I just dont want my 160k motor to take a crap on me. Im lookin for 6-8psi daily (intercooled) or more from the old beast.
Old Nov 15, 2002 | 07:44 PM
sporkcrx's Avatar
rydaddy what happened to your b16 plans? anyways, i've been boosting on my a6 at 5 psi for a couple weeks now, it's going up soon w/ the addition of a new intercooler and fuel system...welcome to the darkside by the way, this is sporkcrx from your other board
Old Nov 16, 2002 | 02:13 PM
Rydaddy's Avatar
Default Re: d16a1 pistons + d16a6 motor + boost = ? (spoon2)
Oh whats up man? Damn money issues are screwing me. I was originally goiing to swap in a b16, but I have been doing a bunch of research and decided to boost the a6. Its more cost-effective, more power to the ground, and its BOOST! Damn, I want to take a ride in your rex and see how it feels with boost! What did you replace (if anything) before you dropped in the turbo? I think I will PM you with a bunch of questions.
dfinch7813
Apr 4, 2010 09:13 PM
trytomake
Dec 8, 2008 11:30 AM
scspeed
Sep 18, 2008 02:26 PM
92EG8
Apr 24, 2008 07:37 PM
grimple1
Mar 20, 2004 12:25 PM
