Can someone help me with the Wheel specs
They’re 15x8 what else do you want to know? I’m sure if you’d take the time out to look up your own wheels a bit you’d find the offset too.
If you can measure the width from front edge to back edge and then from the back edge down to the mounting surface which you have pictured... then we can calculate what the offset is. There is a "20" stamped into the back mounting surface and this MAY be the offset. Since it is stamped 15x8JJ, the outside to outside measurement should be very close to 9".
