Change Final drive d16a9
Old Feb 4, 2019 | 12:10 AM
ochumi's Avatar
Default Change Final drive d16a9
Hi i have a d16a9 (if im right L3 - gearing should be the same as a JDM ZC) i want to put a larger FD
1st - 3.25
2nd - 1.944
3rd - 1.343
4th - 1.033
5th - 0.878
Final Drive - 3.888
what options i have??
thanks
Old Feb 4, 2019 | 05:11 AM
scelestus's Avatar
Default Re: Change Final drive d16a9
L3 D-series transmission Info
https://ecomodder.com/forum/showthre...ios-26279.html
This should get you started. There's a lot of info out there if you're willing to look.
Old Feb 5, 2019 | 08:58 AM
24TEN's Avatar
PHANTOM MENACE
Final drives are interchangeable with the Si transmission found in the states. With that said, you can do that or use an aftermarket final drive set meant for the Si.
DARKTEG_
Aug 19, 2006 06:56 AM
DARKTEG_
Aug 17, 2006 02:43 PM
