Cooling System Fluid Replacement
Old Jan 31, 2019 | 11:52 AM
civic05tx's Avatar
5 Year Member
Icon3 Cooling System Fluid Replacement
This is my first time changing the coolant in a car so I'm need of detailed help. I have a 1995 Honda Civic EX coupe with approximately 176,000 miles. I got the car from someone who did do dealer maintenance but I only know they changed the timing belt in the last few thousand miles.
I have tried searching and came up with the following:Other questions:
  • The coolant is currently a bright greenish color. No rust. I purchased the Honda coolant from the dealership but it's red. Is this newer (?) formula coolant compatible with a 1995 Civic EX?
  • The reservoir next to the radiator has lots of black crud in it. How do I remove it to clean it?
Is there a beginner's guide with pictures and/or videos that explains how to do a coolant replacement on a 95 Civic EX? I'm not completely helpless but I like details and I like doing things to manufacturer specification. Virtually everything I've found so far assumes prior experience or has some kind of omission.
EDIT: Isn't there a new way to flush the system using a hose/pump system that avoids having to open petcock valves, hoses, etc.? I think I've seen some of the quick oil change places do it that way. I don't know what they are called of if they're any good.
Thanks
EDIT: Been searching for hours and I think I finally found what I needed.... https://www.docdroid.net/bs7ChjF/95-...ing-system.pdf
Last edited by civic05tx; Jan 31, 2019 at 07:31 PM. Reason: Added question at the end.
Old Jan 31, 2019 | 02:36 PM
dslpower's Avatar
Default Re: Cooling System Fluid Replacement
I just did mine this past weekend. Follow the link and go to the cooling section, will give you a step by step of how to drain and fill.
https://cardiagn.com/1992-95-honda-c...repair-manual/
Old Jan 31, 2019 | 03:49 PM
egsleepercivic's Avatar
weird that it is red, maybe something I don't know about
I recently bought coolant from the dealer and it was blue Type 2
Old Jan 31, 2019 | 07:40 PM
civic05tx's Avatar
5 Year Member
You're right... it's Honda Genuine Type 2 (blue).
Old Feb 1, 2019 | 05:48 AM
mk378's Avatar
There is a block drain plug on the front side of the block near the transmission end. It may or may not come out after being there 25 years. But it's not that important to drain the block if you fill with distilled water a couple of times and drain it out through the radiator. There will be some distilled water left in the system. Since you know the total capacity you can add the right amount of concentrated coolant to end up with a 50:50 mixture.
For best results you should disconnect the radiator and heater hoses and flush those parts separately from the engine. Initial flushing with tap water is fine.
Old Feb 1, 2019 | 06:36 AM
honda coolant is pre diluted, do not add water to it.
If you are flushiing which Im not really a fan of a little water left over will be ok.
If the fluid coming out of the radiator\block is still bright green, I would just drain and refill I would worry about taking the bolt out of the front of the block.
If you want to flush the radiator, disconnect the bottom hose and dump a gallon of distilled water through it.
as far as your video all 92-00 are pretty much the same, only difference i think is the 96+ don't have the air bleeder on the upper water neck coming off the block
I purchased one of these although I have not used it yet, which should make bleeding the air super easy.
Amazon Amazon
When you replace the thermostat I would recommend getting an OEM one from honda with the gasket, then when installing make sure to lube the gasket with coolant and also there is a little bypass that should be position up, just pay attention to the old one when you take it out
Old Feb 1, 2019 | 09:00 AM
tony_2018's Avatar
Fish Twig
If you want to drain the block there should be a hex bolt on the block, either behind the headers or on the back of the block. Crack it but be careful not to strip the threads.
kaivorth
Honda Civic (2001 - 2005)
16
Jun 11, 2013 08:31 AM
EM2Nena
Apr 2, 2011 10:53 AM
I-have-VTECH-yo
Apr 16, 2006 12:43 PM
briq4
Feb 17, 2006 08:44 AM
TurBoXBirD16
Jun 5, 2002 04:54 AM
