All d series water outlets are compatible
Old Jan 27, 2019 | 10:53 PM
89ED's Avatar
Default All d series water outlets are compatible
except for d17 today at the junkyard I had to get myself one for my ef. Mine has a bleeder screw. For the most part I would say the first generation of these water outlets are the ones with bleeder screws. The second generation are the ones with the same casting style but the bleeder screw hole is not threaded and there is no bleeder. The third generation I assume are the other ones. The bolt holes line up the same for all of them. When you go to pay if you decided to. Just let them charge you for a thermostat housing. Water outlet will most likely not be an item in there system and they’ll have to make up a part and it will be probably more expensive.
ZootownEG
Engine Machining & Assembly
Jun 5, 2019 11:44 AM
done
Feb 23, 2009 06:50 PM
niceguysfinishlast
May 11, 2008 01:39 PM
donkiman
Aug 8, 2004 06:41 PM
