Crack fixable? Hairline crack between coolant passages
Old Jan 21, 2019 | 11:03 AM
eh2_Trav's Avatar
Default Crack fixable? Hairline crack between coolant passages
I pulled this gsr head from a swap I purchased and noticed that is a hairline crack between two coolant passages. It was assembled by a shop so I’m surprised (kinda) that they didn’t tell the guy his head was cracked. Long story short is the head repairable or do I really need to worry about it. I was thinking the repair would be easy to drop a few beads across the crack then get the head milled. I don’t think the hairline crack would really matter and unless you overheat the head it shouldn’t get worse but that’s a complete guess. I never ran a head with a hairline crack like that. Curious to see if anyone ever ran a head with a small crack like this. Thanks for any suggestions or advice.
Old Jan 26, 2019 | 01:05 AM
turbociv910's Avatar
Default Re: Crack fixable? Hairline crack between coolant passages
that head is trash.
Old Feb 2, 2019 | 05:58 PM
CasperBones's Avatar
I don't see why you couldn't. I have seen way worse damage repaired. Groove out the crack, weld it up, scratch it off. Just do a thorough check of the rest of the head before you put it into service. There may be other issues that the heat that cracked it caused.
Old Feb 8, 2019 | 03:18 PM
linkdeezie's Avatar
Originally Posted by turbociv910
that head is trash.
X2 ... depending on how DEEP the crack actually goes beyond the surface
Old Feb 8, 2019 | 03:47 PM
What difference would the depth make? Even if it goes all the way through into the water jackets, so what? Prep it and weld it out.
Old Feb 11, 2019 | 05:42 PM
Tegranosaurus's Avatar
x2
guys have fixed heads from over porting as well just make sure whoever is welding it isnt a hack
eh2_Trav
Engine Machining & Assembly
Jan 27, 2019 09:51 AM
eh2_Trav
Transmission & Drivetrain
Jan 21, 2019 11:00 AM
KooK
May 30, 2003 09:27 AM
Eg6_JDM
Oct 21, 2002 05:47 PM
