94 civic GSR swap AC problems
Old Jan 20, 2019 | 01:12 PM
MikeB18c1's Avatar
Default 94 civic GSR swap AC problems
hey I put a new compressor on a new dryer yesterday and filled it with freon on my 94 Civic with a GSR swap when I turn the AC on it seems to bug the car out really bad does anyone know how to fix that problem
Old Jan 20, 2019 | 01:50 PM
BrianRabbit's Avatar
Default Re: 94 civic GSR swap AC problems
When you say "bug out," what are you referring to? Does it drag down on the motor, make any noises, or do lights or other functions of the car not work?
When I had the same set up a while back, the only issue I ever came across were bad connections ( old plugs ) to relays. It would cause the compressor to click on and off randomly.
Pass along more information on your issue and lets get this solved.
Old Jan 21, 2019 | 05:47 AM
mk378's Avatar
Why was the compressor changed? If the old compressor blew up inside, bits of metal from the compressor go into the condenser and clog it up, the condenser needs to be replaced.
WHat are the high and low pressures? If it is excessive high side pressure causing the engine to "bog", other reasons besides clogged condenser include overcharged with refrigerant or oil, refrigerant mixed with air (failure to use vacuum pump before charging), and condenser fan not working.
Old Jan 21, 2019 | 06:04 AM
MikeB18c1's Avatar
Compressor was never seized up the bearing was going and was not cooling so I decided to switch the compressor and dryer it has new spark plugs and wires less than 5000 miles on them and it has a brand new distributor that I put on the same day I did the AC compressor I'm still haven't mess with the wiring too much yet but the ECU was definitely pin so I'm not sure how they did it so I probably need to figure out the 94 Civic diagram and the GSR diagram to figure out all the wiring and see if they pin the ECU right unless you have any other suggestions
Old Jan 21, 2019 | 06:33 AM
tony_2018's Avatar
Fish Twig
Did you pull a vacuum?
Old Jan 21, 2019 | 06:36 AM
MikeB18c1's Avatar
Yes it was vacuumed
Old Jan 21, 2019 | 06:47 AM
tony_2018's Avatar
Fish Twig
did it hold and at what psi?
Old Jan 21, 2019 | 06:55 AM
jdmark1's Avatar
Yea could just be a wiring issue if it looks like the ecu was previously re-pinned. I would search online for pin diagrams of the gsr P72 ecu and pair that with a 92-95 civic electrical trouble shooting manual just to make sure all of the wiring is how it should be. It could also just be overcharged as well but we'll need a little more than "seems to bug the car out" to actually help you.
MikeB18c1's Avatar
PS and held pressure fine I believe it was around 28 to 30
Old Jan 21, 2019 | 07:44 AM
MikeB18c1's Avatar
Well thank you for the help and I will keep you updated let you know if I fix the problem
Old Jan 21, 2019 | 08:35 AM
tony_2018's Avatar
Fish Twig
If a gsr was added then the only pinned wires would be for the vacuum 2ndary vtec and the ac portion should've been left alone. My assumption.
Old Jan 22, 2019 | 06:01 AM
jdmark1's Avatar
Oh I know, but it's worth looking into to make sure everything else is how it should be and wasn't messed with.
Old Jan 22, 2019 | 09:53 AM
tony_2018's Avatar
Fish Twig
true, possibly wiring fell off since its and old ride.
MikeB18c1
Jan 20, 2019 03:09 PM
MikeB18c1
Jan 20, 2019 09:15 AM
P73typeR
Jun 27, 2005 06:15 AM
