Honda CR-V & Element 2WD & 4WD Element & CR-V
2016 CR-V AWD maintenance: rear differential fluid
Old Jan 20, 2019 | 11:09 AM
minna44b's Avatar
Default 2016 CR-V AWD maintenance: rear differential fluid
My 2016 CR-V AWD Touring is just over 3 years old. It has 17,500 miles. When do I replace the rear differential fluid? The Maintenance Minder is not displaying anything but the local mechanic is saying it should be replaced.
The manual is unclear: the Maintenance Sub Items table on page 445 says code 6 means "replace rear differential fluid * " but there is no * note beneath the table.
Old Feb 3, 2019 | 11:40 AM
punis_her's Avatar
Default Re: 2016 CR-V AWD maintenance: rear differential fluid
20 thousand kilometers for changing..says honda turkey..
Old Feb 3, 2019 | 12:20 PM
Chrisfrom1986's Avatar
Originally Posted by minna44b
My 2016 CR-V AWD Touring is just over 3 years old. It has 17,500 miles. When do I replace the rear differential fluid? The Maintenance Minder is not displaying anything but the local mechanic is saying it should be replaced. <br /><br />The manual is unclear: the Maintenance Sub Items table on page 445 says code 6 means "replace rear differential fluid * " but there is no * note beneath the table.
Ask the local Honda service advisor, not someone trying to charge you for services you might not need in a brand new vehicle.
codysam
Aug 20, 2017 07:44 AM
klrman
Sep 30, 2013 04:09 PM
Luke Lumanto
19
Nov 22, 2012 12:09 PM
Toooloud
Acura TL, RL & ZDX
Oct 14, 2002 03:29 AM
