B-series transmission casing
I have a a cable tranny that has a really good gear ratio, i took it apart and all the gears look amazing and it ***** smoothly, the only issue is that the case is trash most of the motor mount threads are stripped and generally just poor condition, could i find another b series case and swap the gears into it?
of course you can
but something tells me that what your really asking is if you can use the hydro b series casing
or if you have to use the cable b series casing since thats what you have
am i right ?
am i right ?
If it's the internal threads in the aluminum case that are trashed, you could have them helicoiled, or have timeserts put in. But to answer your question, yes. Caoboy hit the nail on the head - check the clearance and re-shim as required if you swap guts to a new case.
h23vtecDA
May 24, 2011 07:15 PM
mugenef9dx
Feb 24, 2004 08:26 PM
incubus
Oct 3, 2002 06:09 PM
