honda b20 swap axles on civic ek hatch
I hav a 97 civic (ek) ej6 hatch that im putting a b20z in from a 99 crv and a b16 transmission. My issue is the intermediate shaft from the crv's bracket doesn't line up with the block as its kinda kicked out, preventing the bolts from lining up. Also the ends of the axle shafts wont go through the civic d16 hub. Anyone?
You need to use an intermediate shalf from an integra or em1 civic si.
Make sure to get the corresponding driver side axle as well, to fit the intermediate shaft, the passenger side axle won't matter as long as it's b series.
Iirc CRV hubs are bigger which is why your axles aren't fitting the knuckles.
Manual Integra.
the intermediate shaft may be male or female on the axle side which is why you need to get the correct driver side axle.
Don't worry about the hub size, get Integra axles and they will fit. You don't have the correct axles or intermediate shaft.
OverBoostDemon
Mar 4, 2010 09:53 AM
jdmb1697ek
Aug 10, 2006 05:00 PM
ottobell22
Jun 14, 2005 12:46 PM
