1997 civic hatch(cx) rear disc... will this work? What els I need?
Old Jan 11, 2019 | 06:28 PM
Ekayix's Avatar
Default 1997 civic hatch(cx) rear disc... will this work? What els I need?
T
itle basically says it all...looking to do rear disc will this work for my 97 hatch? It’s cx ... new to Honda ... safe tos dune it’s the same chassis as ek?ek hatch? And if it fits what else would I need. Thanks !!
Old Jan 12, 2019 | 05:01 PM
Ekayix's Avatar
Default Re: 1997 civic hatch(cx) rear disc... will this work? What els I need?
Originally Posted by Ekayix
T
bump?
Old Jan 13, 2019 | 11:15 AM
notsleepin's Avatar
Not sure if you really need anything extra. Maybe better lines? But my 94 coupe has rear discs and it looks like it was a pretty straight forward swap
Old Jan 13, 2019 | 10:43 PM
saywhat's Avatar
You will need 99-00 Civic Si emergency brake cables.
Old Jan 14, 2019 | 08:02 AM
hondacurious's Avatar
I used the sedan e brake cables form the integra when I pulled the RTA's off at the junkyard. They fit but are a little shorter and you have to just bypass one mounting bracket. I'm ordering si brake cables to change though cause it bugs me that's it not right. You might as well pull a forward LCA from a 96-2000 civic while you do all this so you can install a sway bar later. The cx and dx model did not come with the needed hole for the sway bar link to install. I would also rebuild the entire thing too while you are there.
Old Jan 14, 2019 | 08:30 AM
Freedo_Civegra's Avatar
Proportioning valve?
Old Jan 14, 2019 | 09:02 AM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
You will need disc "brake lines" at the rear because the drum lines do not fit the calipers. A good set of Russell stainless steel brake lines for a '99-00 Si would be a good investment.
Old Jan 14, 2019 | 01:21 PM
saywhat's Avatar
Not necessary. 96-00 hatchbacks have the same valving as 99-00 si.
Old Jan 14, 2019 | 02:13 PM
Ekayix's Avatar
so the cables in addition to this package for sale?
Old Jan 14, 2019 | 02:14 PM
Ekayix's Avatar
ok cool.... now in addition to this kit, the lines... what else will I need? Also if I want to replace rotors are the front and rear the same or I will have to order 2 different sizes standard front then si set for rear?
Old Jan 14, 2019 | 03:03 PM
One92Eg6's Avatar
if you are swapping 94-00 integrarear suspension you'll 94-00 Integra rear disk. I not sure that 99-00SI is the same as 94-00 Integra. while you them out i would consider upgrading your trailing arm bushing.
Old Jan 14, 2019 | 03:30 PM
They are the same on the rear.
Old Jan 14, 2019 | 04:00 PM
Ekayix's Avatar
i am not doing suspension just the arm, bushing, caliper, lines.... eventually coilover system but I’m sure I will need a different set than a standard (ek) coiloiver system ?
so the parts I’m ordering .....
the above pic
-disc, trail arm, lines, new bushing while I’m already doing it, most likely new pads and rotors.... and the e brake cables .... that should be it.... I think. If anyone knows any little thing I’m missing let me know ex. Like the pins etc save me a headache please lol
Old Jan 14, 2019 | 04:20 PM
I think I used Russel braided line kit for a Civic Si.
EDIT: Yep, I just checked my build thread to verify: I used a kit for 99-00 Civic Si.
Blu-Sky
Honda CR-V & Element
Feb 21, 2019 05:45 AM
Angelsbeamer
11
Jul 28, 2017 03:24 PM
Lil Rick
Jan 25, 2011 04:30 AM
DETALZ
Jun 21, 2007 07:06 PM
1.8_crx_what
Jul 9, 2004 01:49 PM
