94 Civic LX A/T will not start warm
Stancetard Hate Monger
Helping a buddy out, since I have two garages full of free (to him) parts. The car is an all stock 94 Civic LX, d15b7 a/t. It will start cold, first start and run and drive great until it is turned off. Once off, it must sit 10 minutes or so before it'll start again. He paid to have the coolant sensor (on the head) replaced, a new IACV, plugs, wires, and igniter. Symptoms persist. My first thought was main relay, but since the car will make its first start in hot ambient temperatures, I am not so sure it is the culprit. I also seriously doubt ignition switch, since it suffers no drivability issues or stalling. Thoughts? Engine is healthy otherwise.
I will give that a shot tomorrow. Haven't gotten as far as a compression check, only had the car for about an hour today. Even though I seriously doubt that the main relay is the issue, I will open it up and check it out tomorrow, and I will also be temporarily mounting an OEM z6 distributor to it to completely rule out the parts store one on the car.
Tried to do that today. The non stop rain/hail/thunder made that nearly impossible. Tomorrow should be better.
Basically go through the whole "cranks but won't start" drill, during the time while the engine won't start. Testing things when it is cold and will start won't tell you anything.
hard to do, I get a 10 minute or so window and it'll start again. it being cold here isn't helping, it restarts quicker.
it's 30 degrees here today so I can't say definitively for sure that I fixed it, but after swapping out the "new" parts store distributor for an old oem ill-fitting z6 one that has been in my basement for a number of years, it fired up after running at idle for over an hour, twice. i don't even know why i bother to look at anything other than distributors on these cars anymore.
Dave88LX
Aug 6, 2012 10:03 AM
gruegrimman
Oct 5, 2007 03:04 AM
RustyDX
Feb 23, 2004 10:14 AM
