ABS & Wheel Lift
Old Jan 4, 2019 | 10:19 AM
ross2004's Avatar
Default ABS & Wheel Lift
I'm researching retrofitting an ITR ABS setup into our ChumpCar Prelude as I've heard it's a very good piece with its four channel modulator and programmed well for track use. My question is how it does with the inside rear off the ground, as we will do in certain corners. Will it freak out and go into limp mode?
Old Jan 7, 2019 | 07:42 AM
aw614's Avatar
10 Year Member
Loved
Default Re: ABS & Wheel Lift
I never experienced any weird issues when the rear wheel is off the ground, on RE71Rs, I have not tried the ABS on r comps. I have the ITR prop valve + ITR ABS ECU in my 2000 LS. The rest of the unit components should be the same across all 98-01 integras
Old Jan 7, 2019 | 09:28 AM
ross2004's Avatar
That's great, thanks. We don't run r-comps- have to use 200TW tires. I'm gonna give it a shot.
Black R
Oct 24, 2012 06:22 AM
young noob #2
16
Oct 10, 2008 09:38 AM
rmcdaniels
Jul 28, 2006 07:34 AM
psegs80
Dec 25, 2005 05:05 AM
yaksplat
Aug 23, 2001 08:42 AM
