1998 accord no fuel after crash,cutoff switch?
Old Jan 4, 2019 | 05:21 AM
Linus Tuleborn's Avatar
Default 1998 accord no fuel after crash,cutoff switch?
hi! New membrer here
i have an issue with my 2,0L accord -98.
a coupple weeks ago i crashed my accord into a ditch and since that it wont get any fuel, all the lines looks to be okay and i’ve changed the fuelpump relay with no sucsses to start the car, it gets no fuel to the fuelrail, i have reed about fuel cutoff switches and now im asking you guys if there is any type of switch in my car and were it is located.
Old Jan 4, 2019 | 03:40 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 1998 accord no fuel after crash,cutoff switch?
No safety switch AFAIK. 2.0L? What market is your car from?
Verify all your fuses are working correctly, and verify that(if applicable) that your security lamp(green key) turns off. If it stays on or is blinking then your PCM will not allow the engine to start/run.
Old Jan 4, 2019 | 05:03 PM
PROBLEM SOLVED!
i found the switch, it was hidden on the right of the drivers side(left stering) ounder the carper
Old Apr 4, 2024 | 03:49 AM
Fullsender's Avatar
Originally Posted by Linus Tuleborn
PROBLEM SOLVED!
Do you have pictures by any chance I can't find no switch I don't have a carper in my car and I've looked behind the dash to the point I've removed the dash (it has to be replaced anyway)
dnick7000
Sep 20, 2019 04:47 AM
flat tire
Mar 12, 2012 02:27 PM
Bilster
Feb 28, 2012 02:08 PM
smileycvc
Dec 4, 2006 09:02 PM
src176
Aug 31, 2006 07:53 AM
