has anyone ever bought a new iacv for their y8. Brand new from the parts store? O’Reilly has them with life time warrenty for $165 !!!! Dang that’s where I’m going to get mine. I hate the junk yard I’m so reluctant to give those fuhkers my money. I hope it fixes my idle.
Yes post your install review. Do you know if there’s a gasket coming with the iacv? I’ll try cleaning it after I get a gasket for it from Honda. If they still sell them. My cars also asking for an o2 sensor but as of now she starts up fine but will just die unless I gas it. 🤦🏻*♂️
i bought an extremely cheap chinese one for a y7 on ebay for $10 or so shipped. worked/works fine. could be lucky, but odds are any parts store is just reboxing the same cheap crap.
I bought the Duralast one from Autozone once for my 89 CRX Si. It turned out to be an OEM Denso repackaged in a Duralast box. I hooked it up and the only noticeable difference was how the idle was a little bit quicker to react to ECU changes. It didn't fix my high-idle-at-startup problem whatsoever. I took it back.
btw, i cleaned mine out the first time, and the idle problems came back, no looking to take it off and clean it a couple times a year.
thats exactly why I want to just buy a new one. It wasn’t even that dirty to begin with and I’m pretty sure I destroyed it. I’m going to buy one from eBay like y’all maybe I’ll buy two just in case. For the record my car starts and dies if I don’t give it gas. I forget if it still does the thing where it will die even if I’m pumping the gas.
i got one for my d16 in 97 del sol s. bought it off ebay for like 40$ or sum and it runs fine and no issues. i tried cleaning my original one out and it didn’t work...
adjust idle, reset ecu, relearn idle? This setup you're running is something I haven't tested yet on a b-series but what I suggested is something I would do next anyways.
Yeap.. I done adjust idle, reset ecu and also relearn idle it was the same...
I using p28
With b20b . I heard that from a guy say that is possible the aircorn draw too many amp ask me to replace to smaller compressor.. Now i outta of idea..
i bought new one from ebay, made in china most likely. part number was correct, and it said it was for civic vx.. so i bought it.. had no issues at all. still working great to this day.
i mentioned that I’m using a y8 manual intake manifold are you using the same ???
no, I am sharing my experience with aftermarket IACV. You can go to hondapartsnow.com to find the correct part number for your car..
for the y8 the part number is: 36450-P2J-J01
