how much of a difference did your headers make?
Old Nov 13, 2002 | 07:57 PM
RegRedTeg's Avatar
Default how much of a difference did your headers make?
i have a 94 Ls integra with just aem ca intake, and tanabe racing medallion exhaust. How much of a difference will headers give me?
Old Nov 13, 2002 | 08:21 PM
ITR#132's Avatar
Default Re: how much of a difference did your headers make? (RegRedTeg)
You should feel a difference.
Old Nov 13, 2002 | 08:26 PM
jabroni95gsr's Avatar
Default Re: how much of a difference did your headers make? (ITR#132)
95 gsr with i/and e/ the header made the biggest difference...it increased tq! DC sports 4-2-1
Old Nov 13, 2002 | 08:31 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Default Re: how much of a difference did your headers make? (jabroni95gsr)
https://honda-tech.com/zerothread?id=329602
Old Nov 13, 2002 | 08:35 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: how much of a difference did your headers make? (FrostyDC4)
I didn't notice too much of a difference with my DC 4-2-1's when I had them. Probably because I only had a short ram intake and an axleback at the time.
recovering stunna, y0
Anyway....most people recommend going with the 4-1 and you definitely should feel the difference with that.
Old Nov 13, 2002 | 08:50 PM
B94Cast's Avatar
I installed DC Sports 4:1 headers, and noticed a nice difference in the upper RPM range. Previous to that, I had installed a 5zigen cat-back, so I am not sure how the header alone would have fealt.
Is your exhaust cat back, or axle/muffler only?
I also noticed a nicer sound difference as well.
Old Nov 13, 2002 | 08:58 PM
GSRrR's Avatar
Default Re: how much of a difference did your headers make? (B94Cast)
I could not feel any difference with my heade r. Had DC 4-2-1.
Old Nov 13, 2002 | 09:11 PM
Ferrell's Avatar
Old Nov 13, 2002 | 09:16 PM
Default Re: how much of a difference did your headers make? (Ferrell)
the dc 4-2-1 distinctly made more power for me lower in the rev band. part throttle at 4k was now pretty decent, it was nill before....
Old Nov 13, 2002 | 09:22 PM
Chris's Avatar
HEADER
Unless you have a V8.
4-2-1 for MIDRANGE
4-1 for top end.
Old Nov 13, 2002 | 09:24 PM
jeebusm3's Avatar
Default Re: how much of a difference did your headers make? (Chris)
HEADER
or a v6, or v12.
Old Nov 13, 2002 | 09:26 PM
threatcon13's Avatar
New User
Default Re: how much of a difference did your headers make? (gtravsr)
i doubt that the 3 or 4 horsepower any average header gives you is "noticeable". Maybe the butt dyno is getting influenced by some optimistic thinking.
Old Nov 13, 2002 | 09:37 PM
aznmc16's Avatar
Default Re: how much of a difference did your headers make? (ALLMOTORDC2)
i had the jdm dc 4-1.. i felt alot of gains.. there's a dyno chart somewhere that shows that it gives around 10hp to the wheels.
Old Nov 13, 2002 | 11:06 PM
frogsr's Avatar
don't know bout you guys, but after changing up my stock header with an aftermarket one (2.5" collector) driveability changed a whole lot. let's not confuse this or correlate it with 'power' but the car was a different animal after the new header. takes a while to get used to, but now, i like it.
Old Nov 13, 2002 | 11:55 PM
gsrvx's Avatar
New User
Default Re: how much of a difference did your headers make? (frogsr)
IB Modified JG Header on b18c1. I felt a difference. Dyno showed increase of 11whp in midrange and 6whp peak. Also 6ft-lbs of torque gained.
Old Nov 14, 2002 | 01:01 AM
hitop's Avatar
Default Re: how much of a difference did your headers make? (RK)
Same here. Thinkin about going w/ DC ceramic or stainless 4-1. I've heard that the ceramic can be prone to cracking though, but then again the stainless is supposed to throw off more heat in the engine compartment. Decisions...
96 LS
http://www.anycities.com/silverteg/
Old Nov 14, 2002 | 01:24 AM
darius's Avatar
Default Re: how much of a difference did your headers make? (hitop)
I've never felt anything with any header I've ever added, the biggest basic bolt on gain I've felt was definitely a race cat converter. Gotta go 1 piece, and look at the weld's on the inside of the header, if they look like crap, send that thing back, I should have in the past but never have.
Old Nov 14, 2002 | 04:41 AM
B18Redline's Avatar
if you have money get the comptech 4-2-1 header. If you don't want to spend too much, get the DC ceramic 4-2-1.
I had the dc 4-2-1 without exhaust, and it made a big difference. How could I be sure, you ask? Well I have a friend that I raced almost every day, and we were dead even most of the time. Well after I put the header on, I pulled about a 1 1/2 car lengths on him.
Old Nov 14, 2002 | 04:42 AM
B18Redline's Avatar
I assume this was a 4-1??
Old Nov 14, 2002 | 05:32 AM
PM-Performance's Avatar
on my R i had the JDM 4-1 and right off the bat i raced it the next day with only that change the 1st run i knocked off 3/10's off my times.
Old Nov 14, 2002 | 08:29 AM
Duck Sauce's Avatar
Default Re: how much of a difference did your headers make? (itr206)
Back when my R was N/A I had a DC JDM 4-1. It made quite a difference in the top end. But on a LS, I suggest you get a GReddy or DC 4-2-1 and a testpipe.
Old Nov 14, 2002 | 09:36 AM
au-gsr's Avatar
Default Re: how much of a difference did your headers make? (DC2ownz)
noticed a difference from 3000 to 5800 top end felt slightly stronger but no major difference.
Old Nov 14, 2002 | 09:46 AM
obd2gsr's Avatar
Default Re: how much of a difference did your headers make? (Redline07)
the JG header is a 4-2-1, and IB modifies it with a 2.5 inch collector.
cheers
MADBADGER
Honda S2000
Dec 26, 2007 06:59 PM
concept11253
Apr 14, 2006 09:48 PM
Heath
Honda S2000
13
Aug 15, 2004 03:43 PM
mushu315
11
May 26, 2004 03:29 PM
el arbi
Nov 27, 2002 04:08 PM
